Yes and no.
Depends upon slope and deck sheathing. Metal roofs can be installed on skip sheathing.
Age: Refer to vender for invoicing.
Life expectancy. Installations, Thickness/Gauge.
Defects: Corrosion. Mechanical damage.
As long as the roof.
Typically, you will not see penetrations on copper and traditional shop manufactured metal roofs. Seams are soldered.
When you inspect manufactured roof panels, any screws should not leak at penetration point unless they did not follow the manufacturer’s instruction. Screws may back out lifting the panel. Then water may gain entry.
My pleasure.
Low Slope Metal Standing Seam roof. Easier to install. Less geometry.
Vent at the eave and ridge.
