Webinars
Recordings
Plumbing Systems with Chicagoland Home Inspectors Inc.
This primer will go over the typical plumbing system from supply to the waste lines. This class recording talks about common terms used in plumbing systems, the types of materials used, and the common problems found during a home inspection.
Length:
longOriginally broadcast on Nov 24, 2020
This is a companion discussion topic for the original entry at https://www.nachi.org/webinars/2020/plumbing-systems-with-chicagoland-home-inspectors-inc
