"Inspecting Portable Fire Extinguishers" online video course
Fire extinguishers are required to be inspected monthly. When performing the inspection the inspector is required to document with a tag attached to the fire extinguisher the date and his intials. Inspect the locking pin is in place, check the hose for flexibility and no signs of any cracks. Check the service dates and that the fire extinguisher is full and mounted properly.
Fire extinguisher service requirements are that that it be inspected monthly with a attached tag showing the date inspected and the inspectors initials.It is required to inspect that it is full, instructions are fully visible and that the locking pin is in place and not tampered with.
Attached is a photo of a portable fire extinguisher that is proper;y secured in place with a an adjustable metal belt. Per the punch out holes on the yellow inspection tag, it is evident that the fire extinguisher has undergone an annual inspection by an appropriate contractor. However, there is no indication that monthly visual inspections are being performed since the inspection tag has not been initialed and dated on a monthly basis.
I read the article Fire Extinguisher Inspection and Maintenance, which defines the five types of fires that apply to fire extinguisher types, how to identify visual defects in fire extinguishers and how to identify the potential for a fire extinguisher to not operate as intended due to age.
Fire extinguisher inspections should be preformed monthly. The owner of the extinguisher is responsible to ensure that the inspections take place.A typical inspection does not take long and you can create a short checklist to run through. This can help cut down time.
A failing extinguisher can cause panic and loss of control if a fire was to break out. Ensuring that the occupants of a home or business have good working extinguishers can greatly decrease loss of life and property. Always verify that the occupants know how to use the item.
In the course, I learnt the basic requirements to perform periodic monthly inspection on portable fire extinguishers and how to document the inspection. It is a visual inspection to make sure the parts are intact and the pressure in the can is not below the acceptable level.
I read the article on air sampling for mold inspections. This is very important in order to test the particle level in the affected area in comparison to the sample taken from the outside environment. It will also show the type of mold that are present. It also talk about the procedures and what to consider before taking air samples.
Upon inspection of this fire extinguisher, the cover was noted as broken. Recommended replacement of cover and/or box. Fire extinguisher was in proper working condition. No action recommended. Full report was provided for client who understood what needed to be done.
Fire Extinguisher Maintenance.
Upon reading this article, I learned what kinds of fire they can be used on.
There is essential information about the types of fires they will work on. This is important as each one is specifically designed for different kinds of fires.
Because they are rated for different kinds of fires, it is very important to have the correct fire extinguishers available.
On an inspection of a fire extinguisher you will want to a visual inspection of several components such as the operating instructions and name plate are legible. You will want to check the safety seals for them being broken or missing. The pressure gauge should be checked if available for the needle in the good or green area and not in the red area. The body of the extinguisher should be checked for dents and rust. The discharge hose should be checked for cracks or breaks in the hose. The maintenance tags should also be checked to see if they are up to date on their proper periodical maintenance.
Mold spores are not visible to the naked eye and need to be tested with an air sample. Air samples are usually taken by using a pump that forces air through a collection device which catches mold spores. Outdoor samples should also be taken as a control for comparison to the indoor sample at the same time. Indoor samples should be taken from the middle of the room approximately 3 to 6 feet off the floor. Windows and doors should be kept shut during the sampling. Air sampling alone is not enough and other test should also be conducted such as visual and surface samples.
This picture is a photo of the ceiling in the garage of a home that has living space above the garage. Past work has been done in the garage and the drywall has not been repaired. This is a safety concern as the drywall is the fire separation between the garage and the living space.
The picture I saw was in regards to chimney issues. One of the main considerations when dealing with chimneys is how easily can it be accessed. I recently inspected a 3 story home with a chimney in the center of a slate roof. It just happened that the buyer had a mason out during the inspection to give him an estimate on some tuckpointing of the chimney. The final estimate was $7000.00 do to how difficult it was to access the chimney. Just something to keep in mind when you are inspecting them.
This is a picture of a portable fire extinguisher. This extinguisher has been inspected monthly as indicated by the inspection tag. All items checked are in good condition and it does not appear to need any maintenance, and it is within date for hydro and maintenance.
The article I read was entitled Fire Extinguisher Maintenance and Inspection. The article details how to properly maintain and inspect a fire extinguisher. It details proper documentation and what things to look for on an extinguisher to ensure it will be servicable when needed.
This fire extinguisher is dented and should be replaced. Dents, corrosion, cracks in the hose or missing pins are a few of the items checked. The 2010 version of NFPA 10 in paragraph 7.1
states: The owner or his agent is responsible for
inspecting and maintaining the portable fire
extinguishers.
A monthly quick check should be done on all fire extinguishers. This can be performed by a non certified person. A few items to check: The nameplate instructions should be legible. The extinguisher should be in a designated area and access must not be obstructed. Pressure gauge indicator must be in an operable position.
Im doing my essay on a commercial window water penetration test. Most test are performed at 12 psi. Which is equivalent to 8 in of water per hour rain. The inside of the window has an airtight chamber around it and is put under negative pressure to test for penetration
