"Inspecting Portable Fire Extinguishers" online video course
Im doing my essay on garage inspections. Garage inspections are fairly easy. If connected to the living quarters a 1 3/4 in solid fire rated door is required. And check the auto reverse on the garage door and also check the receptacles
Tagging of fire extinguishers is and clear sign of how long the extinguisher has maintenance done or has its last inspection. Learning the basic essentials to having and parts and correct operational aspects. Also knowing what to look for and how to inspect in working aspects.
When inspecting and fire extinguishers proper location. Where it csn be easily accessible in case a fire was to accure. Making sure there are know flaws in which might cause the extinguishers to be inoperational and unfunctionality of the extinguisher.
The 30 day inspection of portable fire extinguisher is a visual inspection of the extinguisher and it’s content level. An inspector must ensure it is accessible from all sides, the hose is free of cracks and damage and the instructions are legibly posted on the extinguisher. These inspections must be documented once performed.
Performing a 30 day inspection of fire extinguishers is a valuable skill for both the inspector and the client. It is obviously another marketable service for the inspector, but it provides some peace of mind for the client as well. Any inspector would be wise to add this tool to the toolbox.
Fire extinguishers are meant to handle only small fires. If a fire becomes too large or the environment becomes too dangerous, you should know when and how to evacuate the area. If any of the following conditions are present, you should follow evacuation procedures immediately and should not attempt to fight the fire with an extinguisher.
Most fire extinguishers for homes and public spaces are classified as Class ABC extinguishers, meaning theyre suitable for putting out wood and paper fires, flammable liquid fires, and electrical fires. ABC extinguishers use the dry chemical monoammonium phosphate as the extinguishing agent.
I am doing an essay on a crawl space. This crawl space was in my step brothers house. i was doing a inspection for him on his home and came across it. he needs some new insulation installed by a qualified contractor.
Inspection Portable Fire Extinguisher
At the time of the monthly visual inspection of the companys fire extinguisher, Inspector observed the following:
  1. Observed the one (1) fire extinguisher located adjacent to the office door that opens up into the warehouse area.
  2. There were no obstructions to gain access to the fire extinguisher.
  3. Inspector observed the operating instructions to be clearly legible on the unit.
  4. Safety seals and tamper indicators have not been broken, and are intact as required.
  5. Inspector observed no obvious physical damage or corrosion to the unit.
  6. Fullness was determined by the weight experienced while lifting.
  7. Pressure gauge reading indicator is in the green zone.
  8. The label has not been damaged and is in place.
  9. The discharge hose is not cracked or damaged.
  10. The type unit shows its coverage to be for conditions requiring ABC extinguisher.
  11. Observed the unit to be a Kidde dry chemical 3lb. fire extinguisher.
  12. There are no tags on the fire extinguisher, as the owner states that it is new and has not been inspected prior to todays inspection.
  13. Upon completion of inspection, Inspector secured a paper tag with initials for this months inspection, as per state requirements.
  4. Safety seals and tamper indicators have not be broken, and are intact as required.
  6. Fullness was determined by the weight experience while lifting.
Essay - Fire Extinguisher Types
Fire extinguishers are usually found indoors in both homes and business environments. The services that they are designed to offer are directed specifically to putting out or limiting fires that can result in loss or damage to property and personal safety. With respect to fire extinguishers, it is important that all potential users are familiar with not only its ability to be used safely and effectively, but also with the knowledge of what type of fires the specific extinguisher is designed to address. The most common types of classes of fires include A, B, and C types of extinguishers, which show the fire class on the front of the extinguisher. The A class, addresses the basic areas of wood, paper, cloth, and trash. The B class addresses gasoline, oil, paint and other flammable liquids. The C class is designed to address the needs involving live electrical equipment. In addition, the D class is designed to address the needs to combat fires related to combustible metals and metal alloys. The K class can be used on cooking fires as related to vegetable or animal oils and fats. It is very important to be aware of the designated uses for each type of fire classification, due to the danger and injuries that could be experienced as a result of using an improper classification to put out a fire. With this in mind, it is also essential to be sure that your fire extinguisher is checked regularly, to maintain the element of safety required, should a fire condition arise.
NFPA 10 requires monthly visual inspections. NFPA 10 also requires a 6 year and a 12 year hydrostatic test. The person performing the 30 day inspection does not have to be certified. The initials of the person completing the 30 day inspection must write their initials on the tag attached to the extinguisher.
NFPA 10 requires monthly visual inspections on fire extinguishers. The monthly inspection is required to be documented. The fire extinguishers should be located in a designated place, with no obstructions. The safety seals and tamper indicators have to be of approved material and cannot be broken or missing.
Picture is of a fire extinguisher located on the exterior of a building. Tag is current. Gage is reading in the the green zone. The body of the fire extinguisher is in perfect condition as it appears brand new. Pull pin is intact and secured with a tamper seal. Hose has no cracks or holes and mounting bracket is firmly secured to the wall.
OSB versus Plywood. OSB is heavier than plywood which increases house weight and stress. Plywood is more resistant to wet weather as OSB will tend to swell and remain swollen.Cost, strength, and durability are very similar to both products used in construction. Determining what product to use would be based on pure preference.
The above extinguisher was found during an inspection in September 2018. Location and accessibility were good. However, further investigation reveals that the extinguisher was last inspected over 7 years ago. It shows a recharge date of 2009 and a hydro test date of 2002. Extinguishers should be broken down and recharged every 6 years. Hydro tests should occur every 12 years. The AHJ allows for annual inspections of extinguishers. This extinguisher should be pulled from service immediately, due to safety concerns, and replaced with an updated and inspected extinguisher.
Many types of portable fire extinguishers are available for use by homeowners and can be beneficial, if used correctly, in the saving of life and property. In order to be considered safe and ready to use, extinguishers should be inspected monthly. The following items should be considered during the inspection: location should be in an egress path and extinguisher should be easily and readily accessible, no obvious signs of damage should be visible, pressure gauge and extinguisher weight should be appropriate, and test and recharge dates should be noted and within an acceptable range. Any extinguishers that do not meet the previous considerations should be removed from service and replaced or corrective actions must be taken.
When looking at a fire extinguisher a few things to look for. make sure that there is not any cracks in hoses, that there is no dents or corrosion on the tank. look at the gauge to see if the needle is in the green charged area. make sure pins and safety straps are in tack.
When looking at the label of a fire extinguisher. the label should tell if it a A,B,C,D,or K. most B or C are in kitchen or garages. A are typically for wood and paper. A should be within 30 feet of the room. K would be more for commercial. D exinguishers are for hot metals.
