Interesting FPE
Originally Posted By: jpope
Found this one today. Thought it was kinda cool. . .
![](upload://bNUn2r3sDonEXMCwePwNlMYSgLf.jpeg)
![](upload://w4xzJ5wJAYx9CYrd3IINnV4mvZX.jpeg)
Other than the fact that it's an FPE and the double tap, it looked pretty good for 1959
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: pdacey
Nice.
I did a 13,000sqft 16 unit apartment building yesterday. Had 16 of each of these, one for each unit:
[ Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_5140.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_5160.JPG ]
All 16 were in identical condition. Made for easy reporting.
Slainte!
Patrick Dacey
[email protected]
TREC # 6636
www.southwestinspections.com
Originally Posted By: bking
Patrick, tell us what all you reported on those, Its hard to see everything with a picture sometimes.
1st pic. looks like 2 meter bases feeding into one panel and 2nd,3rd meter has nothing coming out the bottom. all 16 the same??
I guess the interior panels were all like pic 2 ?
please explain the whole configuration and the problems noted.
thanks!
www.BAKingHomeInspections.com
Bruce,
The first photo is of a typical SE panel for all of the units. There were 4 service drops at various locations around the building. Each drop went into a 6' trough. below each trough were a series of meter pans. Most of which were not used (someone was planning for a serious expansion). There were 4 active meters below each trough and each one had the panel in the picture below it.
The second picture is of the typical sub panel located in each apartment. They were all identical in configuration and condition. It was uncanny.
Some of the issues were:
SE panels:
double tapped breakers
no GEC or electrode
some strands cut on the end of the cable so it would fit into the breaker
undersized wires on breakers
no anti oxidant on aluminum cables
not labeled
missing knock outs
Sub panels:
located in clothes closet
grounds and neutrals on common bus
inadequate service space in front of panels
All were Zinsco panels
There were also two bulldog panels out on the pool cabana that did not lock when in the "on" position.
The building was 46 years old. For the age of the building, it was in pretty good shape.
Slainte!
Patrick Dacey
[email protected]
TREC # 6636
replacement of all Zinsco’s and FPE STab-Lok panels ? Even in no signs of overheating are present?
I guess the direct answer (for me anyway) would be “no.”
To break it down a bit. . .
FPE Stab-Lok Load Center (whether as service equipment or load side equipment) yes, replacement is advised.
FPE fused disconnects, not necessarily. It depends largely on the current condition of the system. Replacement is recommended if the system looks to be deteriorated, unsafe, obsolete, etc., etc.
Zynsco/Sylvania/GTE - Recommendations for replacement are based on the condition of the equipment, its function (SE or LSE) and its location (interior or exterior).
Minimum recommendations for any of the above is complete disassembly and inspection by a state-licensed electrical contractor to determine the safety, integrity and performance of the system and its components.
Jeff Pope
(661) 212-0738
I don’t outright recommend replacement. I note the possible hazards and recommend further eval. from a licensed electrician.
From this morning's inspection:
[ Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_5256.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_5275.JPG ]
Slainte!
Patrick Dacey
[email protected]
TREC # 6636
Replacement should be advised for safety (IMHO).
Jeff Pope
(661) 212-0738
Originally Posted By: hgordon
Excellent Jeff!!! Bravo!!! Finally a recommendation that makes sense!! Very similar to mine:
Quote:
Licensed Electrician to further evaluate panel for safeness
Yours rocks! Can I use it Jeff?
Harvey Gordon
SE Florida NACHI Chapter - President
[email protected]
Be my guest Harvey. . .
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: dedwards
Patrick,
I guess no one is going to ask. What were the squash doing on top of the sub-panel in your very first photo? Just curious.
Doug,
These were located in public walkways around the apartment building. It was one tenants way of dressing them up a bit. ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Slainte!
Patrick Dacey
[email protected]
TREC # 6636
Patrick,
Okay. Just seemed like a strange place to see veggies. Cant blame them for trying to “purty” up those panels though. Thanks. Doug
Originally Posted By: jschwartz1
To Add to Jeff’s comment…
SAFETY ALERT ? Property is equipped with FPE electrical panels and breakers. This manufacturer has been known to have documented cases of failure leading to fire. For more information about this manufacturer, it is strongly recommended you visit
http://www.inspect-ny.com/fpe/fpepanel.htm for details
Jay Schwartz
Coast To Coast Home Services, Inc
www.Coasttocoasthomeservices.com
Southeast Florida NACHI Chapter - VP www.floridanachi.org
NACHI - Legislative Committee Member
MAB - Member
