Some nice graphics here Nick. Spa tub graphic, might want to add GFCI protections to it. ![]()
Just added air barrier and thermal alignment graphic.
Just added alignment of insulation and air barrier over garage graphic.
Your graphic indicates that the home is "fully enclosed” and that …… the attic is a conditioned space.
That means… that the attic will be “conditioned” to have the same “heat & humidity” in the summer and… the attic will be air conditioned in the summer.
I have found that 99% of the attics only have insulation between the floor joists and do not have insulation in the rafters.
- This means that it is an “Un-conditioned” space.
Am I wrong or … should the [FONT=Arial]air barrier and thermal alignment](http://www.nachi.org/gallery/insulation_and_energy/general/air-barrier-thermal-alignment.jpg) [/FONT]graphic have ended at the ceiling of the 2nd floor?![]()
PS:
A Big THANK YOU to NACHI for all of the graphics!![]()
http://www.nachi.org/gallery/thumbs/lrg-1933-air-barrier-thermal-alignment.jpg
Just added this rigid insulation graphic.
Just put up this one on insulating a cantilever.
Just added where to insulate graphic.
Just put up one on clogged filters.
Nick,
This one is “hard to see” … any way to enlarge the graphic?
Yes. Every graphic has a hi-res version. You can access the hi-res from the link in the paragraph under each and every graphic.
Inspection Gallery
Thanks!
You guys are doing a Great Job! ![]()
Just added this one on attic condensation.
And this attic condensation one from a different angle.
And one more attic condensation angle.
Nick, any news when app will be available for smart phones.
I just added this one on Ice Dams.
… and this 3D version of Ice Dams.
Your a day late with this one Nick i just used the old one on Wed. ![]()
Exterior Foam Insulation just added.
Just added Sources of Moisture.
