Is Dupont's Roof Liner accepted as a SWR
Is Dupont’s Roof Liner accepted as a SWR; it is not self adhering.
On line 8 of the OIR
Self adhering polymer modified bitumen roofing underlayment applied directly to the sheathing or
foam adhesive SWR barrier (not foamed on insulation) applied as a secondary means to protect the
dwelling from water intrusion.
Does it’s definition meet this?
Self adhering polymer modified bitumen roofing underlayment applied directly to the sheathing.
I did not view photos as I am on a small computer right now.
If not then NO. I just re read your post. If it is not self adhering then it does not qualify.
I just was able to view the photos.
Not even close. It is just a felt replacement.
How did you verify that is what is there?
No! It needs to be
