It’s connected to the hot water out. Thanks in advance.
that tprv appears beyond life expectancy
did you get make/model tpr info from the data tag to assure probe was long enough?
this may help http://media.wattswater.com/PG-TP-ASME.pdf
this is what i add to reports on all older than 3yr
Thanks, that’s a handy link. The water heater is from the 70’s so it’s time for it to go anyway.
In addition, the valve cannot be installed on top of any other fitting. The TPR is required to be inserted to a specific depth.
may be allowed by ahj with correct valve see page 5 of the link provided
Hot water line is also leakin
ok to highjack your verbage Barry? That’s some good info.
sure!
once your monthly royalties check clears ;~))
