Keeprite A/C age
Keeprite Air Conditioner
Model: SSC-32-ID
Serial: 5301250576
Does anyone have ideas on its manufacture date?
Thanks,
Chris
KEEPRITE
CANADIAN INDOOR SOLUTIONS ETOBICOKE,ON M9B 0A2
Phone: (416)913-1282CONVERTIBLE HEATING & AC INC ETOBICOKE,ON M8W4V2
Phone: (416)503-8188MILLGATE COOLING & HEATING GEORGETOWN,ON L7G 5T5
Phone: (416)255-5757BENTECH AIR SYSTEM INC. Markham,ON L3R 2R7
Phone: (416)818-1169HOME COMFORT CANADA MISSISSAUGA,ON L5N 4R3
Phone: (416)622-0055ULTRA COMFORT HVAC SYSTEMS MISSISSAUGA,ON L4W1G4
Phone: (905)629-3383WEATHERMAKERS OAKVILLE,ON L6M 3N7
Phone: (905)469-6608A C HEATING & A/C CO SCARBOROUGH,ON M1C 4W7
Phone: (416)282-9398AIR FLEX HEATING & COOLING LTD SCARBOROUGH,ON M1H 1A4
Phone: (416)439-7155BUTTON’S HEATING INC SCARBOROUGH,ON M1X 1L5
Phone: (416)287-7863CELSIUS HEATING & AIR SCARBOROUGH,ON M1V 4Y5
Phone: (416)297-8990MALEK HEATING & AIR SCARBOROUGH,ON M1B 6E3
Phone: (416)714-6359QUINTEC HEATING & COOLING SCARBOROUGH,ON M1S 3J5
Phone: (416)291-3522R & C ENERGYSAVING INC. SCARBOROUGH,ON M1V 4E2
Phone: (647)351-0777VETRO SHEET METAL SCARBOROUGH,ON M1W 1C5
Phone: (416)499-3458Air Comfort Ontario Ltd. Thornhill,On L4J 7T1
Phone: (905)731-3261A. BUDGET AIR CONDITIONING Toronto,ON M6M 2Y2
Phone: (416)703-0571ACTIVE AIR COMFORT INC TORONTO,ON M9W 6v8
Phone: (416)674-8844Active Temp Control Inc. Toronto,ON M1X 1N4
Phone: (416)754-3282ARANHA HEATING TORONTO,ON M6E 4P3
Phone: (416)817-2031BIGELOW HEATING & AIR CONDITIONING LTD TORONTO,ON M1K 1B1
Phone: (416)265-2180BRANCO HEATING & A/C TORONTO,ON M6N 1S4
Phone: (416)767-0948Den-Air Gas Services Heating & Cooling Toronto,On M4C 2Z3
Phone: (416)609-2083EUROPA HEATING & AIR TORONTO,ON M6H 2X8
Phone: (416)537-4296NATIONAL GROUP INVESTMENTS Toronto,ON M9B6L3
Phone: (416)219-8854NATIONAL HEATING & AIR TORONTO,ON M3H 2N3
Phone: (416)457-8966RIGHT TEMP HVAC SERVICES TORONTO,ON M6B3V8
Phone: (416)614-5477WOODBRIDGE GAS CO TORONTO,ON M6C 3R5
Phone: (416)520-3302CLIMATE PLUS INC. WOODBRIDGE,ON L4L 5P9
Phone: (416)336-6000HVAC MECHANICAL SYSTEM Woodbridge,on L4L 1E8
Phone: (647)404-4461MAR-TECH HVAC WOODBRIDGE,ON L4H 1B8
Phone: (416)844-3587POLAR CLIMATE CONTROL WOODBRIDGE,ON L4L 8B5
Phone: (416)742-2328
For that type of number, the first digit is the year and the second and third digites are the week, but only for the 1980s and 1990s. So around July 1985 or July 1995.
Thanks for the info Mario. I hope that you’re doing well.
Cheers,
Chris
Hi Russell,
Thanks very much. I have a feeling that its likely from 1985. I informed the clients that it was an older, less efficient model and that they should budget for a replacement.
Take care,
Chris
Chris, here is how to determine the age or manufacture date
There are at least three styles of serial numbers used by Keeprite.
Style 1
Keeprite – (1994 to present)
Serial Number format: L9447 37886
(This serial number is from another furnace with a similar serial number format).
Date of Manufacture: Using the second, third, fourth and fifth digits of the serial number L9447 37886 you will find the year and week of manufacture. The second and third digits are the year of manufacture and the fourth and fifth digits are the week. This unit was manufactured in the 47th week of 1994.
Week of manufacture: L9447 37886
Year of manufacture: L9447 37886
Style 2
Keeprite – (1980 thru 1993)
Serial Number format: 305123456
(This serial number is fictitious).
Date of Manufacture: Using the first, second and third digits of the serial number 305123456 you will find the year and week of manufacture. The first digit is the year of manufacture and the second and third digits are the week. This unit was manufactured in the 5th week of either 1983 or 1993.
Year of manufacture: 305123456
Week of manufacture: 305123456
Style 3
Keeprite – (1970 thru 1994)
Serial Number format: Z3Z xxxx or ZZ xxxx
(These serial numbers are fictitious).
Date of Manufacture: Using the first group of digits use the last letter to determine year of manufacture. Both of these sample serial numbers indicate that the unit was manufactured in 1977.
Year of manufacture: Z3Z xxxx or ZZ xxxx
Use this chart to determine year
S = 1970
T = 1971
U = 1972
V = 1973
W = 1974
X = 1975
Y = 1976
Z = 1977
A = 1978
B = 1979
C = 1980
D = 1981
E = 1982
F = 1983
G = 1984
H = 1985
“I” was not used
J = 1986
K = 1987
L = 1988
M = 1989
N = 1990
O = 1991
P = 1992
Q = 1993
*R = 1994
Gary
Great information, thanks Gary.
Chris
