I’m digging through IRC looking for answers, looking for peace of mind… Hard to find both:D .
The kitchen light is wired to the same circuit as the garage GFCI receptacles. Is this OK? Haven’t run into this before and doesn’t seem like a good idea.
I figure the electrician did it so the homeowner would know if their garage receptacle tripped.?!?!???
Husband outside working with various power tools while having a “soda pop” or two, trips GFCI while wife is getting the pasta noodles off the stove, lights go out, she gets scared and drops the pot scalding herself then falls into stove and sauce ends up burning her head, torso, arms (lets not even think about the anti-tip brackets ).
I never needed it but I have one of those signal tracers for finding circuit breakers.
I imagine that could be used to trace which reset controls something like a garage recepticle.
Also, in the OP Bruce states that the lights share the circuit with the garage GFIs.
Now we see the lights are on the load side of said GFIs. That is a bit different.
I still see no safety defect, but I would recommend mentioning it as a convenience/annoyance issue.
I have a follow up question.
What is special about kitchen area receptacles that cannot be mixed with lighting or other rooms? As opposed to those in a garage or bathroom?
I guess the code making panels have for years considered that very high draw appliances will typcailly be used in these areas.
This is my best assumption.
