For Sale - 150’ ft video inspection sewer/pipe scope with 512 hz Sonde (Used).
$1,450.00 ($2,227.95 New w/Recorder & Skid)
Kyrie Cam Model 1500S – Kyrie Sewer Cameras (kyriesewercams.com)
Bundle Includes:
Kyrie 1500S Camera
Kyrie Cam Skid KSC10
Kyrie Cam compatible SD recorder
What’s included with the Kyrie Cam Model 1500S?
150 ft Kyrie-Cam color sewer camera (With Sonde)
1.40" diameter color sewer camera head (submersible) with 10 super bright LED lights (bright, clear color picture and water-tight!)
512 hz Sonde for locating purposes (Works with any 512 hz locator).
**3/8" real sewer video cable push rod**
7" color flat screen monitor in a water-tight case
Professionally welded and powder coated frame (not painted!)
10 spoke drum for maximum durability
Color: Orange and black
Push cable length: 150'
Reel frame: 20" L x 16" W x 27" H
2" - 6" diameter lines (3"+" lines recommended for sharp turns)
(3) rubber feet to keep the camera off the ground when turned on side for use
USA made
The Kyrie Cam 1500S comes with a 512 hz Sonde that enables the camera head to be located up to 15 feet underground. The Kyrie Cam 1500S also has a larger control box than the 100’ cameras, which allows extra storage space for camera accessories.
Frequently asked questions:
Is a foot counter included on the screen? On the Kyrie Cam Model 1500S no foot counter is included. Please see Kyrie Cam Model 1500S CTR or Kyrie Cam Model SL 1500S CTR if a footage counter is desired.
Can the video be saved? If you would like to save or record the footage from your Kyrie Cam please see our listing for the Kyrie Cam compatible SD recorder under Accessories as an add on feature. (included with this listing)
Where is the Kyrie Cam made? All Kyrie sewer cameras are handmade in the USA by a professional welder with years of experience. We are a proud supporter of US made products!
How easy is the Kyrie Cam to use? Whether you are a seasoned professional or have never used a sewer camera before, you will find the Kyrie Cam very easy to use!
Is there a camera skid available to purchase? Yes, we recommend purchasing a skid to help protect the camera head and center the camera head in the pipe. The compatible skid for Kyrie Cam Model 1500S is skid Model KSC10 available under Accessories. (included with this listing)
I have closed my business and am moving out of state. I used this as an add on service.
Camera is in excellent condition. If you have any questions, would like pics or video or more information, please email me at [email protected] or call/text 720-588-2288. I am located in Littleton, CO.
Thank you,
Jason
