Ladder Safety Training Course
Backflow is the reversing of water from the intended normal direction. Backflow can be a problem because it can spread contaminated water back into the system. Devices and assembly are installed to prevent back flow from becoming a problem or happening.
According to the World Health Organization, the United States leads the world in ladder deaths. Each year, there are more than 164,000 emergency room-treated injuries and 300 deaths in the U.S. that are caused by falls from ladders.
Most ladder deaths occur from falls of 10 feet or less.
Ladders that are not in use should be laid on the ground or put away. A client may be tempted to climb the inspector’s raised ladder if it is left unattended, which is never a good idea. Similarly, the inspector should never use the client’s ladder;Man attempting to slide down a ladder, subsequently gets hurt
This picture illustrates the proper use of an extension ladder. Notice that he has a three point connect with both his feet using one hand to grab the ladder and the other hand to work. He also is not above the highest level of safety limitation, two rungs from the top of the ladder. He’s properly position with his body right in between the supporting rails and is not at risk of loosing his balance or at risk of the ladder tipping over.
Building permits are just as important as anything else that is your list of things to check for when looking into buying a residential or commercial property. They are for new construction or any renovations to an existing property to verify by an inspector that all work being done is in accordance to all building codes. An owner of the property or the contractor working on the property can apply and pay fees to obtain a building permit. Don’t be mislead, just because you are the new owner of a property doesn’t mean that you are not responsible for what was built, added on or not done under proper to code before your held ownership. You meaning the new owner can forced to pay all fines and bring the property up to code before any new construction can take place. These situation can be avoided by doing your research checking with an attorney to pull the building permit records is always a good way to protect yourself against any unwanted surprises before the purchase of the property is finalize. Also is you have the time to seek the records and documentation on all permit activity and final inspection report you can do so by visiting your local building department.
Efflorescence for Inspectors:
Efflorescence is the dissolved salts left on the surface of porous materials when water evaporates. Porous materials wick water from any water source, including ground moisture, through a capillary action. While the Efflorescence alone is not a problem, it can indicate a moisture problem and should be addressed with the home owner.
The photo illustrates both safe and unsafe elements of using a ladder. The worker depicted has a proper, three point connection to the ladder while he is working. His weight is properly centered on the ladder as the center of his belt does not go past the rail of the ladder as he is reaching. The ladder is, however, an aluminum ladder and is clearly within 10 feet of electrical lines, which is an unsafe condition.
Although a telescoping ladder is easier to store, carry, and utilize in small areas, it can fail easier due to the moving parts/locks. It is important to inspect these ladders before and after each use, and to discard if any safety issues arise.
Attic Pull-Down Ladders: There are several defects that can be found on pull down ladders. The most common is homeowner installs with improper nails, cut trusses, loose bolts, and missing fasteners. It is important to check the structural integrity for your and your clients safety prior to use.
This essay is about a folding stepladder type two commercial 225 pound rating its 8 feet high recommended that the highest standing point is 5 foot nine meaning you should never go less than two steps down from the top of it the Rons are made of aluminum
Is essay is relating to different drying rates and concrete floor at Grade if the subgrade has no vapor barrier the concrete will dry on the surface and at the Sub grade. before the middle and theres less resistance to shrinkage with the vapor barrier in place theres a more uniform dry times
This is a six foot Type 1 Aluminum step ladder with a 3 foot 9.75 inch maximum standing level, and a paint pail shelf.It was made in 2008 by Husky.It is operated by opening the hinges to the full and locked position.
I have learned that ladder safety is a critical part of using ladders! Ladder accidents are the primary cause of construction worker deaths in the United States, which has the worst safety record in the world! By following safety protocols, the Home Inspector will minimize their risk of injury or death.
This is a picture of a telescoping ladder. If you look closely near the siderails next to each rung, you should see small green dots where the locking pins are located. According to the directions for proper use, the ladder is safe to climb if the green dots next to both side rails are visible when in the extended position. The ladder shown may be defective. You can only see the green dots on the left side, not the right side. The green has faded away, probably due to age and may be considered for replacement.
I was reading an article on ladder safety. I passed the general safety course, but missed some questions on ladder safety. I was surprised to learn that most construction deaths occurred from falls of 10-feet or less from falling off ladders.
Ladder accidents happen more in the U.S. and the picture attached is one of the reasons why. In the picture you can see a man on a very tall ladder that is being supported by 4 individual buckets. A ladder should never be stood on at the top two steps now should a ladder be used is not tall enough and needs additional support to reach a certain height.
What to charge for services can be hard to figure out and its very important to make sure you are not selling yourself short. It’s important to figure out how many hours on average it takes to do a home inspection so you can do the math and make your business profitable.
Inspection Assignment
Picture shows how NOT to use a ladder to access a roof. The incorrect ladder is being used. The picture shows a step ladder being used where an extension ladder should be used. The ladder does not reach to eave, so the top, or cap, of the ladder had to be stepped on to reach the roof. There is nothing to support the person after improperly stepping on the cap of the step ladder to get to the roof. Not that it would help in this instance; however, no ties or safety harness was used. Wouldn’t want to be the guy coming down with this setup after getting up there.
The article chosen for Research Exercise of the Ladder Safety Training Course was titled How to Write a Mission Statement for Your Inspection Company by Nick Gromicko and Kate Terasenko.
Ive read and been part of developing many mission statements for a variety of entities, from government, non-profit and private. This means Ive seen and created a few. Throughout the process or researching, editing, or creating, it always struck me how mundane most mission statements were. This left me with the feeling that there was no real value in having such an instrument.
This article covered the subject in detail while being concise (without going into needless detail that would detract from the learning opportunity offered.) It lays out what a good mission statement should contain while offering explanations on how to accomplish writing your own mission statement tailored to your company.
I especially liked how it left me with the understanding that a mission statement should not be a boilerplate blurb or paragraph. A successful (or useful) mission statement should be personal, about you and your company after all, you are your company. So, ultimately, I had a light bulb moment after reading and considering this article.
Delamination of the fiberglass is shown in this photo. When the ladder shows signs of deterioration it is important to discontinue use of the ladder, mark the ladder as unsafe. The Continued use of this ladder resulted in rail separation
