Load bearing wall
Originally Posted By: jane molina
Wh t is the best way to identify a load bearing wall that ilooks like a partition wall? How can you tell if you have a load bearing wall . double studs on all outside wall but how about inside patition wall.
Jane
Originally Posted By: lungar
Hi! Jane;
If you look in the What’s new section for the visual aid inspection frames
section 2 there is a good picture of bearing walls. By the way are you doing inspections if so how come you haven’t joined NACHI yet???
Regards Len
Originally Posted By: ekartal
Hi Jane,
Welcome to the NACHI board. You will likely receive a much greater response to your questions if you can just give us a hint of who you are! I know I have asked before but no response... ![icon_smile.gif](upload://b6iczyK1ETUUqRUc4PAkX83GF2O.gif)
Erol Kartal
ProInspect
Originally Posted By: tallen
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Hi Leonard
I am not working on the field with a home inspector . This is all new to me and a challenge
also to do something different. That is why you will sometimes see me ask really dumb questions because it's all new. My father says there is no such thing as a dumb question, I will go with that. I am presently working at a
fitness club teaching fitness classes . 2002 I won miss fitness in the the
central valley and it was quite an acheivment. I just like houses and am
trying to do something different and this is . hows that .
Jane
Hi! Jane;
Great reply, and your dad is wright there is no such thing as a dumb question, that’s how we learn, wish you luck in your endeavor as a home inspector.
Regards Len
Originally Posted By: Randy Mayo
Jane
Load bearing walls come in all shapes and sizes you can not tell by just looking at the wall itself. You have to look to see if the wall is actually supporting any loads. In a basement you may find load bearing walls supporting the floor joists in lieu of a support beam and columns or you may see a load bearing wall supporting the main beam in lieu of columns.
In a one story ranch style house with engineered trusses only the outside walls are load bearing, the interior wall usually are not load bearing. However the same house with a rafter & joist style roof will have some interior load bearing walls usually down the center of the house.
Two story houses and many of the more complex houses may have load bearing walls anywhere in the house. So if you are not sure don't guess call for a reputable contractor to evaluate or a structural engineer in the more complex cases.
