I have never seen this type application before which made me have some reason for concern. The LVL main beam was not supported at the end, but had another LVL next to it. On another part of the floor joist the LVL was twisting. Has anyone seen this before and would you call it out.
Definitely call it out, twisting LVL, unsupported bracing and wood wedge will compress causing settling. Looks a little unorthodox as well. Framing contractor definitely at a minimum and possible consult by SE
Recommendation for a Qualified Licensed Building Contractor is highly recommended.
One that is an expert in crawlspace framing and moisture management.
Some knowledge of basic plumbing installation would be helpful. :)
