Make Our Own Report Software
Yep - we have a DJI Osmo Action 5 (basically a higher-end GoPro) which can handle 4K. But file size at 4K gets really big with inspection-length videos and that slows everything down quite a bit, so we’ve landed on recording in 2K for now and that works well enough for our purposes.
Cheers!
I thought of a similar concept. Use audio to record my timestamped comments and while still taking my normal photos (timestamped as well), then have the AI use my audio comments to find the appropriate report narrative and grab the associated photos to add to the report. I am not a software engineer, so have not tried to build it. Also, I would want Spectora type of report output, so waiting to see if Spectora comes somewhere close to my idea with their AI work.
Ian/Brian, you guys hit the nail on the head regarding the server/maintenance barrier. AI can spit out code all day, but keeping up with secure cloud image hosting, mobile PDF compression formatting so realtors can open it instantly on-site, and daily tech support is a full-time job.
I’m playing around with a lightweight, unbundled markdown PDF reporter built specifically for solo guys who want to get away from Spectora’s bloat/Fixle data mining.
I put together a master spreadsheet grid of standard residential defect comments structured by system (Roof, Elec, Plumbing) with the exact Observation → Implication → Recommendation formatting banks look for, just to test the data layout. If you guys want to check out the text file or want me to DM you the raw layout sheet to see if the verbiage matches what you use in your Word templates, let me know. Happy to share.
Grok just released Grok Build. Specializing in code creation…
https://x.ai/cli
Yup.
This morning, I have 8 guys in the field.
One of them, his template, wouldn’t download. We tried everything, but nothing worked. None of the other 7 had any issues.
So we contacted customer support, they did something on their end on the server level, and it downloaded just fine.
That’s why I can’t see myself having custom software. There was zero reason to have this kind of error, but it happened, and it took tech support to fix it.
If I were still a one-man shop, I could risk it. But with a team, there is too much to go wrong unless I hire a full-time tech person.
Utkarsh, can you PM me what you posted that got deleted, please?
A lot of odd deletions have been happening since they “tightened control” on this forum.
And, some of us are not sure it is going well and we need info to encourage changes.
After hearing about what Spectora did, I decided to build my own system using the following tech stack below. Yes, I am a AWS Solutions Architect; and thats another story and for another day. I’ve been with InterNachi since 2015, but like so many others working two jobs and struggling. I closed out my IT career of 32 years thanks to getting let go over cut backs and AI - So, I’m back in Florida and starting life again as an inspector. I don’t trust companies with my data, and especially with my customer data, so I did what I thought best, and built my first software application by myself using Claude Code for AWS and few other tools below.
AWS Platform, Git Hub - Repos; AWS-CLI - Input; Claude Code - My DevOps / SecOps; Claude Cloud Desktop - Forms and Contracts; Email Engine - MS 365; Document Control - Docusign; Accounting package - Claude / AWS; Appointments & Scheduling - Claude Code; Marketing & Designs = ChatGPT Total Cost: $50 per month and $30 of that is from Docusign.
I am still testing the platform now, and hope to have it completed on July 1st. I am going to invite you to come and take a look at it now. https://marketing-test.pro-sightinspections.com/ and provide your feedback. I also have a full working tool to use for the inspection work itself, however I don’t have an opent token / key set availble for public viewing. So you’ll just have to look at my photo for now. I’ll have the web url availble thru 6/7/26
some of the links are broken and nothing opens up when you click on it. i was wondering what you use to put the report together. i am making my own software and am using python with django, mongo db, word, and some html and css. still in the testing phase though, i run it locally on my home server right now. the ai polish works well on the comments though, takes a few words and makes a paragraph out of it. i like the look of it, it’s similar to mine although yours is a better layout, but i’m not a programmer though so i expect that. very nice indeed. how long did it take to make it work?
Hi Tim, Sorry about the links I had realized when I read your feed back that its because I’m in the testing and had those as non-puplic facing links. When I have the cut over completed, I’ll pass that along to you. Thank you for the great feedback. I am letting Claude Code build it and he is using mostly a combination of Bash commands, Python, and Json for the biggest part. I spent several yesterday on the new 4/26 Wind Mitigation form from Florida, and I have to say that its a bit of challenge to add because of the font sizing and types they used. But Claude got it, and man oh man does it work great. He scanned the entire document from my PDF, wrote the grid, and pushed in to a custom build frame with Json, and just nailed it for every fill in spot, blank line, and checkbox. That made me just almost jump out of my chair when I got the validation URL. back. It made my whole day worth while. It has now in two days, working at about 9 hours per day; built my standard home inspection for florida, my wind mitigation, my 4 point insurance, my pool and spa, and my drone inspection templates along with my reports, and agreements. Once I got the framework down it has been a great experience. Today, we are finishing up the commercial template, agreements, and the report. I had it build, on the frontend; a full customer booking system with a separate customer and agent portal, so my reoccuring customers and agents can view their reports, with MFA security, and full video controls . I was really suprised just how well Claude Code can do this. I can’t wait to show you.
mine took about 8 months so far with about 250 hours of actual coding time spread across that. i have a few projects that take more time like my passive network tap running zeek and rita. i can get 1 gbps capture without dropping a packet right now, copper, mm fiber, and sm fiber. that is the main focus right now while this takes a back seat. i use chatgpt and gemini. claude was way too wonky for me as far as actual usage. never could get it to go for more than an hour or so coding. and the free tiers ensure that i don’t spend all day every day coding, they almost force a break on you when they revert to slower models.
Tim, HI - Oh I agree, when I first started with Claude I was using the web version and it drove me crazy. Then a friend of mine, said what are doing…no wonder your going crazy. Said basically I should have been using the Claude Code that runs from your local powershell via the AWS CLI tool, and everything becase soooo..much beter. I learned fast never to use the web versions.. there just not built for this at all.
i may give that a try. i heard that claude just took a dump as far as ability though. i really need to get my network tap finished by the end of the month. gonna do a talk on it at h@ck3rcon this year.
I’m a software engineer with experience building for the home inspection field. Happy to help if you or your stepson run into questions along the way.
I appreciate that. I’m actually working with Claude right now on it.
