Are your clients buying a New Home without a Home Inspection?
That could be their biggest mistake.
New Construction Inspection
There are good reasons to have a professional inspection performed on the brand new home your client is buying.
Buying a new house is likely one of, if not the largest purchase decision your client will ever make. The whole process is fraught with emotion and stress. A professional home inspection will substantially reduce the risk for their large investment in a new home. It just makes sense to learn as much as you can about the quality of your new home, before signing off on everything.
Building a new home is a tremendously complex endeavor. It involves many people, usually split up into sub-contractor groups, each working on different parts and systems of the house. Even for the best builders, it’s nearly impossible to complete this process without missing something. Maybe its a plumbing fixture that didn’t get tested for leaks, maybe its an electrical box that isn’t working, or any one of dozens of minor problems that can easily be overlooked in such a major undertaking. We will find such problems while it is still early enough for you to bring them up with the builder and have them corrected before your client sign-off and start moving in.
For the relatively small cost, a professional inspection of that new dream home can pay big dividends in peace of mind and getting any problems identified and corrected before they can become an unpleasant surprise.
But, the house was inspected by the City or County Inspector!
Did you know that many county building inspectors inspect over 30 new houses a day, that’s less than 15 minutes at each site!
After more than 6,500 inspections personally completed by Jose Roig, he has identify the 10 Most Common Defects in New Construction.
<LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>No insulation installed in the attic <LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>Missing proper roof vents, or vent holes cut, but roofed over <LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>Cut trusses in roof or floor trusses <LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>Windows installed improperly <LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>Missing backing blocks at tubs and showers <LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>Cooling vents missing, not connected <LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>Inoperable or missing GFCI’s in required areas <LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>Hot and Cold water reversed at faucets, tubs, showers and toilets with Hot Water supply <LI class=MsoNormal style=“MARGIN: 0in 0in 0pt; TEXT-ALIGN: justify; mso-layout-grid-align: auto; punctuation-wrap: hanging; mso-list: l0 level1 lfo1; tab-stops: list .5in”>Tempered glass missing in required areas
- Improperly installed roofing and flashing.
Don’t wait until is too late. Next time your client ask you: Why do I need a Home Inspection for my New House? Remember these facts and protect your Buyer and Yourself.
Call now at 321-402-2211
Jose G. Roig
Owner/Consultant
A & P Building Consultants
www.Inspector1.com](http://www.nachi.org/forum/)
