Above the garage there is a decent crack. After some research it doesn’t seem to be related to the foundation but a shrinkage crack. Since it’s larger than 1/8th inch I believe I’m supposed to report it. Would I recommend they seal it up? I’m guessing this is a good point for water to enter.
The second picture is the same garage, smaller crack at what appears to be a cold joint (is that the correct term?). Do I write this up and tell them not to worry about it but to keep an eye on it? Recommend they seal it as well?
Thanks for the help!
