A few points for design;
Statergies;
∙ Keeping water and precipitation out
∙ Managing plumbing leaks
∙ Avoiding condensation inside the building and its envelope
∙ Controlling entry of humid outside air
∙ Controlling indoor sources of humidity
∙ Designing assemblies to dry out
∙ Providing mechanical ventilation and dehumidification
Air barriers play an important role in moisture control. “We didn’t have moisture control problems until we insulated our buildings and then, to make matters worse, began using materials that were subject to moisture damage, corrosion, mold, and mildew, such as OSB, steel studs and gypsum sheathing.:)
See here. Free to use whatever you want.
http://deckerhomeservices.com/2009-082%20Decker.pdf
http://activerain.com/blogsview/1149958/water-instrusion-problems-in-chicago-condos
http://deckerhomeservices.com/Sample_Reports_files/Sample%20Water%20Intrusion.pdf
I also sent Kenton a Power Point.
Teaching a State Licensed CE course on the subject, tomorrow night, at our Chaper meeting.
Seems a former ASHI chapter Pres. is attending, as well.
Hope this helps;
thanks guys
