system
(system)
Originally Posted By: ajalowsky
Three day work week anyone???
system
(system)
2
Originally Posted By: aleleika
two day work week for me.
A. Dan Leleika
www.a-teamhomeinspections.com
system
(system)
3
Originally Posted By: bkelly2
Done today, Happy Thanksgiving.
system
(system)
4
Originally Posted By: Aimee Jalowsky
False is the correct answer. Happy Thanksgiving
system
(system)
5
Originally Posted By: jjackson
It is one of the choices on the Real Estate Exam prep test to eliminate water in basements. According to the test, it IS a solution to basement
dampness. Along with sump pumps.
system
(system)
6
Originally Posted By: jwilliams4
wet basement problems"
A humidifier will not correct the problem. The problem is the entry
of water into the basement. A humidifier will only help to remove
the moisture that has accumulated as a result of the problem. And
not necessarily all that effectively. It will not effectively eliminate
any problem, either...it is only an aid in the elimination. Other
measures must be taken to correct and eliminate problems.
system
(system)
7
Originally Posted By: psefzik
Jae,
A humidifier is designed to add moisture. Increasing the problem.
A dehumidifier is designed to remove moisture. Solving some minor moisture issues.
Phil
system
(system)
8
You’re right…I wasn’t paying attention!
system
(system)
9
Did you notice it took over a week for someone to catch that?
Good job, PS...
