Found multiple neutrals and grounds under one lug. Couldn’t find anything posted in the service panel indicating it was capable of handling multiple wires. I just wrote it up as in need of further evaluation by a qualified electrician. Any ideas?
Double tapped neutrals can expand and contract enough to the point where the connection becomes loose. The loose connection could overheat and cause a fire.
It needs to be referred out to a qualified electrician for CORRECTION not evaluation. You already evaluated it.
You’ll get the hang of it, William.
Here’s a good document you can link to, usually clarifies the issue of the neutrals
Can Multiple Neutral Conductors be Terminated in a Panelboard Termination?
