My first florida moisture intrusion inspection
When we test, we find water migrating through the block and would pool at the base of the wall at the slab.
Matt, Don’t rule out the obvious!
I did an eval on a home on Labor Day. Four years ago the owners had moisture up the walls and around the baseboards, staining and mold. The builder came out and repaired the stucco, sealed the stucco, sealed the control joints, added a french drain, sealed the windows, etc…then Fay came through and they had exactly the same problem as four years ago. I checked out the home and found some staining in the fireplace.
Here was the problem.
THE HOME IS 5 YEARS OLD
:shock:
wow, that is pretty bad.
I did go up on the roof, both of the second and partial first floor.
I took some pics of vent pipes that didnt seem to be sealed really well, and recommended repair.
Actually, after consulting with Shawn, I think I was getting false positives with my GE Aquant meter on the second floor.
See, there should be a metal mesh for the stucco on the second floor only.
This would explain my high readings.
There was nothing in my instruction manual about false positives with metal…so I didnt know.
Why would they want 5/8" or less stucco on the side of the slab?
When the stucco on all the rest of the house is even thinner.
Should there be a void between #1 and the wall that is above it?
