Originally Posted By: Brandon Ellerbee This post was automatically imported from our archived forum.
Anyone know what is going on with the videos and book library? It will not allow me to borrow an item. Is it no longer available or is it just down for right now? And when is it going to be back up?
Originally Posted By: dbush This post was automatically imported from our archived forum.
Brandon, this is copied off the front page of the bulletin board:
This is from Chris Morrell, our esteemed computer guru:
If you currently have an account on the message board (if not, see below):
Go to http://www.nachi.org/bbsystem/profile.php?mode=editprofile and enter your CURRENT username and password. You will then be taken to a page where you can modify your account. In the field that's marked "Full Name" put your current members-only username and in the fields that are marked "New Password" and "Confirm Password" put your current members-only password you'll also have to fill in the field marked "Current Password" with your current message board password). Go to the bottom of the page and click "Submit." Once you've done this, you should be able to log into everything with your members-only username and password.
