Need Help with PEX/Shark bite pipe fittings
Look for the mark that the installer is supposed to make one inch from the end of the pipe. The mark is the only way to know when you have pushed the pipe far enough into the fitting. You should see the mark very near the fitting. The technology is old enough so its probably an installer error.
