New image added to the free Gallery: Wall Construction: Stucco Veneer over CMU or Concrete Wall
Keep 'em coming.
The lathe is optional. I do not consider stucco a veneer when applied to masonry. It is a finish coat. Anyone else with me? These are often regional terms. :wink:
You can’t bolt the ledger board to a hollow block wall. The ledger bolts must be secured to a concrete filled or a bond beam. There is typically some additional flashing to weep out any water that gets into the hollow blocks above
