Yes I would never say Spaghetti in a report. LOL and never say Certified alone either it is always in conjunction with Electrical **Contractor **or Licensed Contractor. I do not believe in just saying a Qualified Electrician ever in a report.
In years gone by there was no requirement to staple NM cable when it was ran across framing members and supported by those members, see 336-18 of the 1999 Edition of the NEC. Today NM cable installed in an attic must comply with 320.23 and there is no mention of staples in that section so I will leave the securing up to those who want to argue the point. See 334.23 of the 2008 or 2011 NEC.
I have been deeply involved with the NEC for many years now and participate in many events concerning the education and implementation of the rules. I sit on many committees and boards throughout NC and helped author the Manuals that the Inspector Qualification Board requires Electrical Inspectors to know in order to pass their Standard Electrical Inspector’s Certificate test. Go to nciaei.org and click on committee or officers for more information.
I am certified by the Office of the State Fire Marshall to teach these Standard Electrical Inspector Classes and have been teaching them for 12 years now. Go to randolph.edu and click on the continuing education link and see for yourself what classes I teach.
Tonight I will be at Energizer Battery plant where I teach 70E Safety in the Workplace and the National Electrical Code to the maintenance department. I have been working with the cooperation’s throughout my area for several years teaching 70E as well as the requirements of OSHA.
In these classes we look at the trip curves of many different breakers as well as the available heat energy per square centimeter for different voltages and situations. Most hate the math involved.
On this site I do not try to get involved in a lot of code or other matters as in most areas around the country a Home Inspector cannot quote code nor can they make repair recommendations unless they hold a license in the field they are addressing.
In days gone by the quoting of codes on this site brought down the wrath from hell on the one quoting the code section therefore I try to refrain from doing so. The bottom line was how safe is this. At any rate trying to call out something as being a defect by today’s standards that was perfectly fine at the time the installation was made serves no purpose either.
=D>](,)](,)](*,)=D>=D>
Mike
I appreciate your response back concerning your credentials and qualifications. I hope you did not see my concern as a witch hunt.
I am very sensitive to issues that arise concerning code and proper methodologies. In my area, we have three electrical instructors that are questionable in their competency. One I know for certain is not competent. The other two I worked with years ago and corrected many, many issues behind them.
The one in particular I took a CE class several years ago he taught. He teaches at a community college.
In his class he actually had a demostration set up with a GFCI receptacle. He used a wood stool, a plastic bucket half filled with water and a power cord. He had stripped 6" of the insulation off the ungrounded conductor. He would place the stripped section in the bucket of water sitting on top of the stool and plug the cord into a GFCI. When it did not trip he offered it as “proof” that GFCI’s DID NOT WORK. At first I thought it was a tactic to open discussion. I quickly realized he was absolutely serious when several in the class remembered his demonstration in previous CE classes. I immediately spoke up and corrected this nonsense. I explained to him there was not a path to ground for leakage current, and as such, all the current leaving the device was returning. The bucket and the stool was sufficient insulation. He started to speak, got a bewildered look on his face, realized his mistake, and immediately started on another topic. He was not the same the rest of the day.
Since then, I have encountered a few of those who either attended his CE classes or was students at the college. You can not convince them that GFCI’s work, are reliable, and actually are worth using. Imagine how many times his students have been on wet or rainy jobsites and decided not to even use cordset GFCI’s since they dont work anyways.
Even worse still, imagine if one of these electricians were called by a home owner about replacing GFCIs that a HI found defective!
I hope that the maintenance guys will appreciate the training. All in all I have found that they are the worst offenders when it comes to code compliance. I am ever more hearing statements like “code doesnt apply to industrial plants” and the “we will never have to get an inspection so why does it matter” by maintenance guys.
In a few words…YUK!
Suggest Running Boards and Proper Securing and Supporting and lastly defer to Licensed Electrical Contractor.
Agreed! Accept I would rather recommend William.:mrgreen:
I know then it would get done right.
Ummm…I agree with Mike…and I have no credentials…I am no body but I still agree with Mikes last statement and concur he is Qualified:)
You made me blush but thanks anyway. Hope to see you next week.
However, I do not believe section 334.23 removes the requirements of section 334.30 where NM Cable is installed above a ceiling In attic spaces along the top of the joists. The “and” within section 334.23 serves to say not only does everything else in Article 334 apply to NM Cable but also the additional requirements attributed to Section 320.23. Section 334.30 would still apply in my opinion.
I guess I should add this as well…the whole premise of making a reference to Section 320.23 is for protection of NM Cable in attics where flooring may be installed or near access openings where NM Cable can be damaged from walking on it, storing boxes on it and so on…has nothing to do with the securing and supporting requirements of Section 334.30…slow down and read it slowly…
But I will say…this is hardly the site to get into a trip curve, copper melting temperature debate. I forget…is this Nachi or Holts site…
I feel it was a worthy discussion for anyone whose work places them near exposed, energized equipment. Many do not realize the magnitude of energy available, even in residential equipment.
When we attempt to preclude those based on the thought that it might not be of concern to them, we may rob them of an opportunity to learn or broaden their understanding.
BTW, I have heard of a Paul Abernathy before, but the one I heard of walks on electrons. Is this the one in the same?![]()
Agreed…all education is good as long as it does not get buried in the logic per se’
As for me…electrons travel through me just like everyone else…and sometimes my electrons are part of a fault as well…
but i have been around awhile…many know me i guess and thats good and bad…
Im just a little different these days…
How untrue. Those electrons are having to fight their way through at least 6 different airport burgers with varying levels of grease and non-conductive fillers. But then knowing you, I can hear the special order now… Let me have a double NOOXID burger with grilled onions. :mrgreen:
Paul A,
Nice to hear from you my friend.
I always liked your methods of explanation.
Your a good man Mike and you have a huge heart…glad i got to spend a day with you my friend.
Ok Steve…now you can change your Avatar…
