Originally Posted By: wdecker
I see it. but mostly EMT.
Here is my point:
Why is EMT needed in commercial but not in residential? Does this make commercial safer?
I know that the Union / local government incest exists and is live and well in Chicago and the close suburbs. But lets leave that aside.
Does having the conductors entirely enclosed in metal conductor make it safer? Of course.
- No rodent chews.
- No physical damage.
- All shortsfrom frayed or damaged wire immediately passed to ground.
- Any electyrical fires enclosed.
If EMT is safer (as the above proves) why not have that as the gold standard. You guys sound like a bunch of old sparkies, 'Hey, it meets code. That's good enough. Whatarya, some kind of stoopid radical?'
The point was made, 'as long as it (Romex) is installed properly'. This incluses stapeling it properly. How often does Joe Homeowner do this?
You ask about running the path. I don't know about you, but I ALWAYS call out holes drilled in the studs of a load bearing wall (which an outside was usually is). The proper way to install conduit (or Nomex, for that matter), is to run it up from the floor, not laterally. More work, yes, but a much better job.
So call me crazy or a stooge of the unions, but I assure you that you are mistaken on both counts.
Safer is safer. 'Safe enough' is a cowardly statement.
Will Decker
Decker Home Services
Skokie, IL 60076
wjd@DeckerHomeServices.com
