Hello All,
Well me and my guys went out to a high end house that we had roughed in a few months ago to move a few recess lights because the owner changes their cabinet layout and wanted them re-positioned which is not a problem.
The Drywall guys had cut out the locations and we proceeded to move them as the romex was long enough since we typically loop extra romex at all recess lights in case this ever has to happen....typical with custom homes.
So we climb up to move the FIRST recess and look up into the hole and guess what i see…
The trim carpenter had come in AFTER the rough in and at the owners request to add supports to the outside edge of the walls for crown molding, and I mean the large fancy molding…owners changed their minds MANY times but I digress…
Anyway we look RIGHT up in the hole and guess what…they added some blocks and DROVE nails RIGHT through our ROMEX and guess what it would have NOT been seen unless they choose to MOVE those lights…
Yes the romex was more than 1 1/4" away from the edge…what happened was they never even LOOKED and simply added the wood and the wire was clearly in view…the NAIL had CUT right through the ungrounded conductor…scary huh…
Point is…NEVER assume other trades will look out for you…this wire was in PLAIN view and makes you PRAY this is the ONLY one that it happened at.
