Pipe Connection Question
From the cut-off … they had a flex hose connecting to the copper piping entering
the house … Is this ok ? Or should it referred to a licensed plumber.
David
You got the missing flashing also, right? Both at the “penetration” and everywhere the brick and siding come together.
Thanks for the missing flashing observation .
Can u join copper piping with the flex hose ?
If that flex connector is an approved material than the answer would be yes. I question the fact that this is a flex connector that is not protected from impact.
