Came across this plumbing component this morning. Water was dripping through the drain pipe. Had to break the photos into two due to shelving located in front of the wall. Could someone explain the purpose of this component? Should water be continuously dripping? Thanks.
Also, with the leg terminating their, that outlet box may not be in the safest spot. Just a thought. It probably meets all the specs and blah blah blah. But you never know what could happen.
