Looking for feedback on this as I’ve never encountered it before. The pictures are from the cold supply to the water heater. There is a gate valve (not 3 way) and what appears to be a drain at the bottom of the valve. This joins the TPR discharge tube.which carries on down into the floor drain. There was drips from the tube when I removed it from the drain.
Ant thoughts on why the supply valve would have a configuration like this?
