Hello, I have two questions. First, is there any issues with this plumbing vent configuration? It appears they did this to prevent sewage odor entering home since the swamp cooler is located right next to plumbing vent. Second question, shouldn’t the plumbing vent be further away from swamp cooler (evaporative cooler)?
I would call it out as an improper modification of the vent pipe.
As to the required distance from the swamp cooler, this may help. plumbing vent clearance from swamp cooler - Google Search
Improper because of vent cap, trap below vent cap and just dumb. The approved fix is way easier with less material.
Hey Lon! It’s Jessica Alvarez, me and my husband were out in Colorado last year for training. I lost your number, hopefully if you see this, you can send it to me! Hope all is well and thank you for your comment
It’s greatly appreciated !
Hey Jessica,
I remember you guys. Good to hear from you.
My number is at the bottom of this post.
It’s not the best way to do it but it probably works fine, especially if you are in an area that doesn’t freeze or get much snow.
If it smells like sewage in the house, yes.
Damage to the shingle will increase over time. Wind is also an issue since it is not secured.
Thank you all for your feedback! It’s greatly appreciated!
Looks like it will break off fairly easily. Strong wind or snow load. Ugly, wrong and stupid!
