I have a 20 amp circuit in my garage that no longer functions. It has 3 two lamp florescent lamps, and 110v outlets. The only full time load is a refrigerator and an upright freezer.
When any load is applied the power goes away and it tests as hot/ground reverse. If the power comes back it tests as o.k.
I have replaced the breaker, disconnected the lights and plugged the appliances to another outlet but power is sporadic and temporary at best.
Roy is most likely correct.
But , if this was my home I’d call a GOOD electrician.
Why Not?
Just the insulation on the wiring burning …will kill you. Yep!
Listen to your main panel or where ever the breaker for this circuit is located. Do you hear any buzzing or humming? Could indicate loose wires in the panel board. Almost acts like your browning out when this is the case. Be careful.
I have opened everything up. Lighting and power are on separate circuits. Everything is tight and the only anomaly was a slightly scorched ground terminal on the upstream outlet. I’m getting 120v but nothing will function. I’m going to replace the two outlets where the scorching is and if that doesn’t do it then I’ll call in a pro.
