Originally Posted By: dbowers This post was automatically imported from our archived forum.
Mike -
It looks like a 90% efficient furnace from your limited photo. If so PVC is the commonly used vent pipe. If in doubt call a HVAC contractor - get the unit serviced and ask him what you've got.
Originally Posted By: rsummers This post was automatically imported from our archived forum.
Mike did you open the unit to see if it had a inducer motor? If the house is only 3 years old I bet it does. That yellow sticker on top of the unit would tell you the efficiency. They would not be able to attach the flue to the outlet if it wasn’t 90%. I think that you should call a pro to check this out seeing how you don’t have enough information on the unit are you a inspector?
Originally Posted By: kluce This post was automatically imported from our archived forum.
This furnace has to have a inducer motor. This furnace can also be installed upright. The gas would be at the top, the exhaust is being sucked down the heat exchanger to the inducer and out the pvc pipe. The blower is at the bottom with a single return flex connected to it. Of course, this furnace is on it’s side but that’s how a lot of furnaces are designed now a days. You can install it upright or on its side.
This furnace could not work without an inducer motor.
