PVC to ABS joints
There is now an approved glue for PVC to ABS joints - and these joints may now be legal.
http://www.menards.com/main/store/20090519001/items/media/Plumbing/oatey/Prod_Tech_Spec/Oatey_ABS_to_PVC_Transition_Green.pdf
I would assume it dries green as well so we will know when it has been used. Might be a bit hard to see the green color against a black pipe. Has anyone used this or seen it on an inspection?
This has been “out” for a long time. Yes, I do see it occasionally & I used to use it myself.
FYI - I’ve also used the red All-Purpose numerous times for ABS/PVC transitions with no problems.
Not exactly.
In WI one such joint between old and new work is permitted and the green stuff has been around for for more than a few years.
See post #5
it is very easy to see…very green…
Good to know. I searched for previous posts regarding this and came up with nothing. Not sure why the one you referenced, Michael, didn’t show up for me.
The main reason I posted is because I am still seeing CE courses say that this is still not allowed, that’s all.
