If someone learns how to do the bare minimum inspection, that is
according to the SoP, then from that point forward, there is no need
for any further education or training, correct?
And… that makes good marketing to the public when you advertise
that “our company does the bare minimum and no more”, yes?
If the SoP is what makes a good inspector, then all home inspectors
are the same, as long as they abide by the SoP. There is no such
thing as a “more qualified” or “better inspection”, as long it meets
the SoP.
We all know that the SoP will cause complaints to go away, because
they protect us. Customers are always reasonable, yes?
The cheapest price is the only thing that makes any inspector different,
as long as they go by the SoP. No wonder the customer looks for
the lowest price, because they know all inspectors do the same level
of inspection (according to the SoP). There is no difference, yes?
We don’t need any more training, education or tools. We have the
SoP and that is all we need, yes?
I’m OK and your OK, yes?
BTW… I know a home inspector that just paid $80,000 for his first
moisture meter. He lost a law suite because he could not “see” the
moisture, decay, mold, and termites inside the walls of a house.
He did his inspection according to the SoP, but the entry point of the
moisture was so hard to see, he missed it. After it was discovered,
it could be seen, but only if you got down in a certain position and
knew where to look very closely. He has been inspecting for 15 years
and is ranking member in another HI association.
After loosing $80,000 he went out and bought a moisture meter
because he realized a tiny little gap can be a major freeway for
water to flow into and may not be easily visible or easily accessible. The
SoP did not protect him, because it requires you to “see” even the tiny,
tiny things that we miss all the time. If you think you never miss these
little gaps… just buy a moisture meter and an IR camera.
James said he is going to buy an IR camera when the price comes
down, but I hope he does not get in trouble for going beyond the SoP.
I have no idea why he wants one.
The more you learn, the more you see with wisdom and the third
eye of your understanding. The demand for quality education and
training is increasing and InterNACHI is leading the way.
Thanks Ben, for all your hard work.
