QOD for 12/28/04 (exterior)
Originally Posted By: gbeaumont
Picture courtesy Eric Van den Ven.
Hi to all,
Here's todays question
Regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : [email protected]
NACHI phone 484-429-5466
Inspection Depot Education
[email protected]
"Education is a journey, not a destination"
Originally Posted By: jrooff
And the correct answer is?
Let battle commence ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Regards
Gerry
Gerry Beaumont
[email protected]
Not being able to see what went on inside and this is assuming that it is in fact a block or poured basement wall, I would not be able to call out D as my answer. That would be a big leap from just looking at this one photo in my opinion.
Originally Posted By: jpope
Those stucco cracks are quite common out here in shaky land (SZ3 and SZ4).
Based only on the one picture, I would recommend sealing and monitoring.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: kdemski
I agree, James. Calling for the big guns seems like a bit much. I’d start with a “reputable” stucco-guy. If he knows a patch won’t outlast his guaranty, he’ll make the call.
Originally Posted By: cradan
Concur with Ken, Jeff and James. If it’s Van den Ven’s pic, I’m assuming it’s Florida. Hurrikins, maybe, but not too many shakers down there. Without a good gander at the underlying foundation wall or slab, how could you make an informed call on whether this is a finish problem, or a truly structural issue?
Chris
http://www.inspect4me.com
Chicago Illinois Home Inspections
My answer was B but I would have added a note to monitor. For this picture problem and seeing nothing else.
Originally Posted By: Blaine Wiley
Very common kind of crack down here. If it were in VA at a basement wall I would certainly recommend an SE. Unless this was a fairly new home, I would most likely recommend repair and monitoring by a qualified licensed contractor.
![eusa_think.gif](upload://lNFeGuTetUAtwNVgUSOuUzgrGGK.gif) How often should the "qualified licensed contractor" come out to monitor it Blaine?
Jeff Pope
(661) 212-0738
Originally Posted By: rfrancis
I might be a way off on this, but here goes. Isn’t that the famous stucco that mold lawsuits are made out of, that would be a concern to me and at the bottom of the report or some where else . I would state something like this If client has a concern about mold recommend further evaluation by mold specialist, now before everyone goes nuts on me remember I said bottom of report or somewhere else in the report. Now as to the crack yes it is larger at on end then the other that would be a concern and that it was running sort of vertical would add to that.
Bottom line have repaired and that client should monitor for further movement and then a structure specialist if movement noted, or something along that line.
Bob Francis
Shamrock Home Inspections Inc
Toronto, Ontario Canada
Originally Posted By: gbell
I would not call a crack of that size common. From the looks of the window this is a wood frame home. I would be concerned about structural movement and possible environmental concerns.
But it is a hard call to make from just this one picture.
Greg Bell
Bell Inspection Service
. The material in the photo looks like the real thing, not EIFS.
EIFS is one or more coats of stucco-like media slathered-over a screed and some rather thick slabs of polystyrene (an oversimplification, but you get the idea). For an EIFS wall to crack like that, someone would have to have mechanically attacked it.
Chris
Originally Posted By: ksutherland
Isn’t the fact that the crack is diganal and not a step crack a hint that the home is framed?
Kevin Sutherland
Good Guy Inspections
Thanks Greg, that was my thinking behind the question, I am no expert in FL stucco problems, but this crack is a big bugger (sorry for the technical term ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif) ) and due to the fact that it tapers conciderably it would have to allude to some type of differential settlement, either in the framing or the foundation structure.
BTW, here is the link to Eric's original post:
http://www.nachi.org/bbsystem/viewtopic.php?t=434&highlight=exterior
Regards
Gerry
Gerry Beaumont
[email protected]
Originally Posted By: jmyers
Gerry,
As usual, I totally disagree with you. You could not possibly tell from looking at a picture of a crack in stucco, or even looking at it personally there was any framing problem here what so ever. Further, an engineer could not possibly tell you that either.
While there is not doubt in my mind that is a stress crack, the cause of it would most likely not be structural in nature. The stucco looks like an after thought and not original to the structure, so my thoughts would fly in the direction of improper installation.
Joe Myers
A & N Inspections, Inc.
http://anii.biz
