system
(system)
April 6, 2004, 12:00am
21
Originally Posted By: rmoore This post was automatically imported from our archived forum.
I actually saw my first 10 amp breaker last Friday in a 1945 partially rewired home. As you can’t go smaller than 14 awg for branch circuits I guess there is a right answer…sort of.
– Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
system
(system)
April 7, 2004, 12:00am
22
Originally Posted By: Bob Badger This post was automatically imported from our archived forum.
jfarsetta wrote:
I submit that the order does , indeed, matter. If there was a 10 amp breaker involved, then #14 would be fine.
Reversed order of answer is incorrect, IMO, as the question gets read in sequece, so the answer needs to follow that same sequence...
Or someone transposed the order when typing the question.
Of course the 10 amp breaker could be used for any wire size listed.
But then again the code would allow all of the following combinations also.
40 amp breaker with 14 AWG
30 amp breaker with 12 AWG
20 amp breaker with 10 AWG
10 amp breaker with 8 AWG.
Looks like I failed the test my answer is/was C.
My point here is not to confuse, it is to point out there are few 'absolute' answers in regards to the code.
I have written some electrical tests, it is very difficult to ask a question that has one answer.
Bob
-- Bob (AKA iwire)
ECN Discussion Forums
Mike Holt Code Forum
system
(system)
23
Originally Posted By: dbush This post was automatically imported from our archived forum.
Bob, true, but the answer we were looking for was “B” and “for a change”
Joe Farsetta got the explanation correct in the wiring sequence.
Dave
-- Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
system
(system)
24
Originally Posted By: jfarsetta This post was automatically imported from our archived forum.
That hurt…
– Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
system
(system)
25
Originally Posted By: five.five This post was automatically imported from our archived forum.
Thanks Bob for not feeding me to the lions, on the post above !!!
I appreciate your help.
system
(system)
26
Originally Posted By: tgardner This post was automatically imported from our archived forum.
And to think - I scored seven hundred on the non math portion of the SAT’s.
Baaaaaaaaaad question I preferred not to answer. - tg
