I will be passing the torch back to Gerry - so y’all have a good Holiday Week-end. This one is about air/moisture movement.
Well done Claude, thanx.
Thanks Claude,
Wow!
Where does the moisture come from?
Insulation is not a vapor retardant , the attached vapor barrier is though!
Correct answer “unsealed ceiling openings”
