Where the dryer exhaust duct is hidden within the building construction, what shall be permanently affixed and located within how many feet of the exhaust duct connection and why?
There are 3 parts to this question. ALL parts must be answered correctly.
If mounted and closer than recommended, it may create enough pressure to lift or pull wet lint into the fan impeller, resulting in excessive lint loading in the fan
The maximum length of the exhaust duct does not include the transition duct. If the exhaust duct is concealed within the building’s construction, the length of the exhaust duct should be identified on a permanent label or tag located within 6 feet of the exhaust duct connection.
Already been answered.
There are 3 parts to this question. ALL parts must be answered correctly in one post.
The maximum length of the exhaust duct does not include the transition duct. If the exhaust duct is concealed within the building’s construction, the length of the exhaust duct should be identified on a permanent label or tag located within 6 feet of the exhaust duct connection, so the length in known.
