Got a little behind this week, busy as a one legged man in a butt kicking contest.
Questions of the week
Introduction and requirements:
A member of the Award Committee will post a question, at a random day/time.
A competing member may make one post per question thread to answer the question and the member’s winning entry must have all parts of the question answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Winnings will be limited to no more than 6 times in a given year, the objective is to allow as many Members a chance to win as possible.
Any disregard to the above and divulging the correct answers will forfeit the weekly winnings.
So please refrain from participating if you have already won in the maximum for the Year.
First correct answer (as judged by the Awards Committee or Poster of the Question) wins.
The lucky winner will get a case of “Now that you’ve had a Home Inspection Books” shipped to them at their address on file. Make sure your Address on File with Inachi is correct.
Courtesy of Nick Gromicko.
Winners of the Question of The Week shall request their prize by emailing fastreply@nachi.org and submitting their Mailing address for shipping.
Allow 2 weeks for delivery.
The Questions:
QOTW**
- What are the types of heat that must be taken into account when calculating the cooling loads for an HVAC system?**
a. Sensible and radiant heat
b. Radiant and conductive heat
c. Conductive and latent heat
d. Sensible and latent heat**
- Which of the following would be most likely to have the highest R-value?**
a. 6" fiberglass batt insulation
b. 12" cast-in-place concrete wall
c. 2" extruded polystyrene panel
d. Triple insulated glazing system with ½" air spaces**
- An inspector can often determine the approximate age of a home by its method of construction. Which of the following choices shows the methods of construction in order from first developed to most recently developed?**
a. Post and beam construction, balloon framing, platform framing, ICF construction
b. Balloon framing, post and beam construction, ICF construction, platform framing
c. ICF construction, balloon framing, post and beam construction, platform framing
d. Post and beam construction, platform framing, balloon framing, ICF construction**
- When one is inspecting an EIFS (Exterior Insulation and Finishing System) wall system for deficiencies. Where would these be most likely to occur?**
a. Window heads
b. The center of large expanses of EIFS
c. Along the bottom edge of the EIFS installation
d. At the corners of the installation, such as around windows
Good luck inspectors!**
