Welcome To Questions of the Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing [email protected] and submitting your Mailing address for shipping.
Choose your prize from the following list:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
1) Which is the least effect on the deflection of a dimension lumber floor system?
a) Joist width
b) Joist grade
c) Joist species
d) Joist spacing
2) In a forced air heating system containing a split system air conditioner and a humidifier, humidity is reduced by
a) Running the humidify in reverse
b) Condensation at the condenser coil
c) Condensation at the evaporator coil
d) Condensation within the compressor
3) Water hammer can occur as a result of
a) A lack of air chambers
b) Faulty shutoff valves
c) Loose piping
d) Low static water pressure
4) Ice damming at the eaves may be caused by
a) Inadequate attic insulation
b) Undersized gutters
c) Shallow roof slope
d) Improper flashing
5) While inspecting a heat pump in the cooling mode, you measure a 28 degree F temperature difference between the interior supply and return air. You should suspect
a) An exterior fan running too slowly.
b) An overheating compressor.
c) A dirty filter.
d) A thermostat set too low.
