Welcome To Questions of the Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@internachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
1) At what level would water pressure within a single-family dwelling begin to be considered excessive and require correction?
a) 60 psi
b) 80 psi
c) 100 psi
d) 120 psi
2) Gas-fired furnace heat exchanges most often fail from
a) Low temperatures
b) Lack of use
c) Improper gas pressure
d) Rust and metal fatigue
*3) Which has the LEAST effect on the deflection of a dimension lumber floor system?
a) Joist width
b) Joist grade
c) Joist species
d) Joist spacing
4) A basin makes a gurgling sound at the end of draining the fixture. This may be due to
a) Improperly supported pipes
b) Inadequate venting
c) An undersized drain pipe
d) Improper drain slope
5) What is the most common contributing factor to masonry retaining wall movement? a) Corbelled construction
b) Hydrostatic pressure
c) Poorly mortared joints
d) Too many tiebacks
