**Welcome to another round of Questions of The Week !
Questions of the week:
Introduction and requirements:
A member of the Award Committee will post a question, at a random day/time.
A competing member may make one post per question thread to answer the question and the member’s winning entry must have all parts of the question answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Winnings will be limited to no more than 6 times in a given year, the objective is to allow as many Members a chance to win as possible.
Any disregard to the above and divulging the correct answers will forfeit the weekly winnings.
So please refrain from participating if you have already won in the maximum for the Year.
First correct answer (as judged by the Awards Committee or Poster of the Question) wins.
The lucky winner will get a case of “Now that you’ve had a Home Inspection Books” shipped to them at their address on file. Make sure your Address on File with Inachi is correct.
Winners of the Question of The Week shall request their prize by emailing fastreply@nachi.org and submitting their Mailing address for shipping.
Allow 2 weeks for delivery.
**THANKS for being here and good luck! **
1) Combination Arc-Fault Circuit Interrupters
Parallel protection detects arcing between the:
a) neutral and ground
b) hot and neutral
c) hot and ground
d) A-C
e) A-B-C
- True or False
A ground fault parallel arc fault can occur only when a ground path is present.
This type of arc fault can be cleared by a AFCI OR a GFCI
3) The primary leading factor contributing to home heating fires was failing to properly clean _______
- Insulators are materials that have the opposite effect on the flow of electrons. Common insulator materials are:
a) rubber-glass-plastic
b) wood-plastic
c) air-rubber
d) A-C
e) A-B-C
5) True or False
An opening protective smoke barrier is required to be a fire door assembly which includes the door, frame, and glazing, but is not required to be supplied by the same manufacturer
- extra credit!
This song was originally produced in what city?
Third Rate Romance
