A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions, and the eligible member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice! https://certifiedmasterinspector.org/video-contest
Good luck!
A fuse should be rated higher than the lowest rated component in a panelboard to be protected.
True or False
2) In a series circuit, the current has ___ path(s) to take.
a 1
b 2
c 4
d depends on source of electrons
3) The misuse of ___ cause more than three thousand house fires every year
4) A run of electrical conduit may not have more than ___ quarter bends between fittings and outlets?
a 2
b 3
c 4
d 5
5) If a grounded conductor is attached to the disconnect switch, which type of service disconnect must be used?
a Circuit breakers
b Knife Blade Switch
c Fuse Block
d None of the above
Extra Credit
WHO sang this on WHAT song?? Because you will not believe your eyes
Everyone else came real close & THANKS for being here!
Now I’m scared Robert will disagree with some answers.
BUT he has always been here for us in case there’s a discussion on them.
a 1
b 2
c 4
a 1
Every year electric extension cords cause about 4,000 trips to hospital emergency rooms. The misuse of electric extension cords and power strips also cause more than three thousand house fires every year, killing about 50 people and injuring over 250
a 2
b 3
c 4
d 5
c 4
check
a Circuit breakers
c Fuse Block
d None of the above
a Circuit breakers
~~ ~~ ~~ ~~ ~~ ~~ ~~ I didn’t think anyone would get this, but Stephen used great detail with the lyric wording & nailed it!
The Tubes - She’s A Beauty 8,798,411 views
Fee Waybill GREAT singer
