ksimpson2
(Kris Simpson, CMI)
September 17, 2022, 1:46am
Hello mastermind group…
I am taking part in the Fall Realtor Con Ed in which I will have a booth for the trade show and the theme this year is favorite TV show.
I wanted to poll Home Inspectors on the top 5 most common things they find during a Home Inspection.
Mine are…
Inadequate Site Drainage/Missing Downspouts
Missing or defective GFCIs
Double Tapped Breakers
Plumbing Leaks
Deferred Maintenance (Missing caulk, chipping paint, clogged gutters…)
I appreciate all the input and am curious to see what everyone’s top 5 are.
kstreet
(Kyle Street)
September 17, 2022, 1:58am
2
Flashing on sidewalls
Kickout flashing missing
Crawlspace moisture
Decks…just in general. Decks…good grief
Loose toilets, like might-have-a-leaking-wax-seal loose.
bcawhern1
(Brian Cawhern, CMI®)
September 17, 2022, 2:15am
3
Siding/trim moisture damage
TPRV discharge pipe or drain pans
Peeling/weathered paint
Crawlspace moisture
Decks decks decks
mgoldenberg
(Marc Goldenberg, Inspector # HI1365)
September 17, 2022, 2:21am
4
various circuit breaker panel issues
outlets hot/neutral reverse, loose from wall
dishwasher drain line no high loop
clothes dryer non-approved mylar foil
broken roof tiles
ruecker
(Ryan Uecker)
September 17, 2022, 2:24am
5
My inspection software will sort my comments by most used. Here is what it came up with for the top 20. Note: I do a lot of older homes.
bfeltner
(Brandon Feltner, TREC #22952)
September 17, 2022, 12:46pm
6
Ryan, I’m thinking I remember you being a Spectora user. If so, how do you get that report? I would love to use it to clean up my templates.
ruecker
(Ryan Uecker)
September 17, 2022, 2:13pm
7
Go to your template and in upper right hand corner, click on the three dots. Then select “export to spreadsheet.” There will be tons of info colums in the spreadsheet so just delete or hide the colums you don’t want to see.
kleonard
(Kevin Leonard, CPI/CMI)
September 17, 2022, 6:56pm
8
Decks
Electrical issues, usually open grounds, no GFCI and reverse polarity
Decks
Plumbing issues, usually leaks under a sink, leaky and stuck shut off valves.
Decks
lmorrison
(Larry Morrison, CMI)
September 17, 2022, 10:02pm
9
Smoke/ CO detectors (way) older than 10 years old (or other alarm defect in general)
