Discovered considerable structure damage concealed behind rim joist insulation. This area is directly below a sliding glass door, home built 1990.
It pays to look behind the rim insulation, I have discovered similar issues on previous inspections, mostly below doors.
Same thing here from a previous thread. I pull back the insulation, as much as I can. If you saw this post, you’ll see why.(video shot is actually my own house that I’m repairing right now). The inspector (about 9 years ago, when I was doing construction and not inspecting) didn’t look behind the insulation and the sill is rotted out. This guy is still in business touting his 30 years experience.
Unfortunately, we have too many finished basements with drywall ceilings that conceal these problems. A moisture meter is most likely useless unless the water migrates to the drywall surface. I doubt if my infrared imager would detect abnormal conditions in most finished basements that have similar water intrusion issues, although I do scan the rim areas.
