Updraft gas fired furnace in a mechanical room
Electronic lighter
Induced draft with operable blower
Return air door has operable blower shut off switch
Older home
Door to closet has grill on it
Return plenum is below unit
Return plenum grill within 10 feet of this closet
Questions. -
Does IRC 2006 permit a return air grill within 10 feet of this closet if the furnace has induced draft system?
If the door were replaced with a solid door and proper combustion air provided would it be acceptable?
Does the term “firebox” also apply to gas fired fireplace assemblies?
The code I am reading is:
[FONT=Arial]SECTION M1602 IRC 2006. I could paste it but am not sure about copyright.[/FONT]
