Ok here’s the scenario:
house was built in 2007, basement was just recently redone-metal studs were used. In the visible portions of the basement the wiring was improperly supported, no grommets were used, no GFCI was installed in the basement bathroom and the wiring was pulled so tight around the corners it cut into the drywall.
So I wrote the whole thing up and the client was suitably concerned. Now the vendor is saying they’ll have an ESA audit and fix anything that is reported.
will the ESA audit identify defects behind the finished portions or will they just flag the visible portions, ignoring the rest of the basement which is 99% likely to be wired poorly? Anyone know how they “audit” a finished basement?
