Originally Posted By: phughes
What if any requirements are there that indicate a main service panel is to be installed right side up.
I ran into one installed upside down.
Originally Posted By: pdacey
Slainte!
Originally Posted By: mboyett
| Quote: |
| 404.7 Indicating.
General-use and motor-circuit switches, circuit breakers, and molded case switches, where mounted in an enclosure as described in 404.3, shall clearly indicate whether they are in the open (off) or closed (on) position. Where these switch or circuit breaker handles are operated vertically rather than rotationally or horizontally, the up position of the handle shall be the (on) position. Exception: Vertically operated double-throw switches shall be permitted to be in the closed (on) position with the handle in either the up or down position. |
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
