First time seeing one of these connections, and I am not sure how to report on it.
They are prohibited by both IPC and UPC because they tend to leak. Ask your AHJ to verify.
I would check with your local AHJ if those fittings are approved for use in your area.
They are not in some locals.
Section 707 Prohibited Joints and Connections
707.1 Prohibited Joints
The following types of joints and connections shall be prohibited:
- Cement or concrete joints.
- Mastic or hot-pour bituminous joints.
- Joints made with fittings not approved for the specific installation.
- Joints between different diameter pipes made with elastomeric rolling O-rings.
- Solvent-cement joints between different types of plastic pipe.
6. Saddle-type fittings.
Thank you all. I found the code reference for IL and they are prohibited.
Yep, prohibited here, too…
Looks like a leak waitin’ to happen. “Ooh that smell!”
Emergency use or utilities. Proper saddles are too expensive for home use IMO.
That was my first thought too Larry, but it is some type of sealant. Tasted like banana…
LOL!!!..
The lick test is always the best!
Jim is been saying that for years, so it must be. LOL
OMG!!! Hilarious!!!
Me as well, John.
It appears manufactured as a cast iron transition T fitting for the main soil and waste vent, to the soil pipe that connects to a sanitary lateral to sewer pipe. No leaks.
Transition fittings are used to connect pipes of different materials, such as PVC to copper or ABS to cast iron.
Personally, I see no issues but will await for the to chime in as I read the strings.
Oatey® Saddle Tee Kits are designed for tapping into a 3 in. or 4 in.
